Thread: Disposal Switch
    Oct 2011
    Torrance, CA
    Default Disposal Switch
    I keep telling clients that they should not locate their kitchen disposal switch at a height where a child could switch it on. I see nothing in the code that dictates this? Anyone know if that it true?
    Thanks,
    Michael
    Default Re: Disposal Switch
    Quote Originally Posted by Mike Boeger View Post
    Thanks,
    Michael
    A switch for a disposal can be located anywhere you could normally locate a switch.
    Under the counter is acceptable.
    Oct 2008
    Tulsa, OK
    Thanks,
    Michael
    There is nothing in any of the codes that I know of. I am curious why you telling your clients this?? It's not the best thing to make up stuff as you go along. At least with something written in a code or standard you will have hundreds of really smart people to back you up..IMHO
    Oct 2011
    Torrance, CA
    Well, there has been cases, including to my cousin, where toddlers have come up to the cabinet mounted switch and turned it on while someone has had there hand in the disposal trying to clean something out of it. She was lucky enough to pull her hand out just in time. The switch could also be accidently switched on my the person standing at the sink with their hip. I just think it has potential for harm and want to make my clients aware of the risks involved. Just because there is no "code" for something, doesn't mean it doesn't have the potential to harm someone.
    Oct 2008
    Tulsa, OK
    Attachment 29109
    OK, I am not sure moving the switch would help the adult in this case.
    Someone had their hand in the disposal, then a child turned the disposal on?????????
    I guess it could happen, on The Lucy Show.
    Nothing in code to require it but we are home inspectors and paid for our opinions which can go above code. I just always try to differentiate between my opinions and code or minimum standards. Common sense can go a long way to protect people but we also can't protect everyone from their own stupidity.
    Apr 2020
    Michigan
    I see this is old thread - been looking for some info to reflect 2020 NEC code on disposals etc, So as a homeowner and buyer or seller at times; I hope you define in your reports opinion vs adopted state and local code requirements.
    I'm doing a kitchen gut and our disposal wall switch is by sink but now sink will be in island. We can probably still reach the switch with about a 120 right pivot reach.....
    (hands should never be in disposal , period)
    Disposal and 5 amp range hood (large non cab Z-line no microwave) planned on same circuit with a 20 amp panel based AFCI/GFCI .
    Thx
