    Clay White's Avatar
    Clay White Guest
    Default disconnect box needed?
    Default Re: disconnect box needed?
    Quote Originally Posted by Clay White View Post
    1962 home. A/C installed in 2002.
    Service equipment panel located rear of the chimney you see in the photo.
    , the chimney prevents the "line of sight" of the A/C... ...what do you think?
    Clay,
    The service disconnect is not in line of sight thus a defect.
    Let someone else But....But....But.....
    Report what you observe.
    If you were down working on that a/c condenser unit, would you see someone flip the breaker back on? No.
    So either fix it or be prepared to have the a/c technicians surviving spouse's attorney call you regarding an 'avoidable death'.
    Shannon Guinn's Avatar
    Shannon Guinn Guest
    I'm with Jerry. Believe it or not, a $20-30 dollar disconnect could actually save someones life, and it sure would help me sleep at night.
