Results 1 to 3 of 3
08-17-2013, 04:26 AM #1
01-21-2014, 03:09 AM #2
Re: Main Breaker Panel Service lead inlet
Basically, the main breaker is the breaker that the feeder wire connects to. This breaker is a two-pole breaker that is connected to 240 volts to power your home. The main breaker is usually located atop the remainder of the breakers in a panel, but sometimes the breaker panel is installed upside down. Some main breakers are bolted in place and others are snapped in to place like the branch circuit breakers.
Thank you..
Epackpolymers.com
01-21-2014, 12:54 PM #3
