Thread: Arc Fault code interpetation
08-17-2013, 05:49 AM #1
First of all I would like to say I hope you all have been very busy. Mine has been off the hook and it's been a heck of a year hence the reason for not keeping up with this forum.
We adopted the 2011 code which states.
210.12 Arc-Fault Circuit-Interrupter Protection.
(A) Dwelling Units. All 120-volt, single phase, 15- and
20-ampere branch circuits supplying outlets installed in
dwelling unit family rooms, dining rooms, living rooms,
parlors, libraries, dens, bedrooms, sun-rooms, recreation
rooms, closets, hallways, or similar rooms or areas shall
be protected by a listed arc-fault circuit interrupter,
combination-type, installed to provide protection of the
branch circuit.
The new homes I inspect for the majority would have all breaker AFCI unless they are GFCI or dedicated. Heres the kicker there is a few jurisdictions that have been passing non AFCI breakers that supply lets say kitchen lights, laundry room lights, garage lights, etc. If the above code doesn't include the specific room as written they allow a standard breaker.
It just blows my mind that people will dissect the code to save a few bucks. So tell me if I am wrong. Should not "all" circuits supplying outlets be protected if they are not GFCI or dedicated? and why doesn't the code just state that instead of naming the specific rooms?
08-17-2013, 07:11 AM #2
Re: Arc Fault code interpetation
In this case its the electrician. I spoke with him for I call it out every time in new construction. He said exactly that (cost). The builder is unaware of it and this electrician probably got the bid on the homes due to be lower then the rest. With that said he also claimed he spoke with an challenged the AHJ and they could not dispute.
This is why I need the code guys on this forum clarify if the electrician is right. Key words for me in the code is (or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter,).
08-17-2013, 09:14 AM #3
So you are saying laundry, kitchen, foyer, and the like is not similar? Are they not "outlets" in "rooms"?
Please explain in detail what they are trying to address, I don't get it. Why select family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation
rooms, closets, hallways, or similar rooms or areas and not lights and or receptacles in others? It makes no sense to me
08-18-2013, 06:06 AM #4
I appreciate your comments. They need to define similar areas. Not even the locals know what similar areas area. I believe foyer lights to be similar to hall lights. I believe kitchen lights to be similar to the adjoining dining room lights, etc.
So with that said I "can" assume the rooms mentioned to be similar until that is defined.
The only thing the electrician said is it was not specifically stated the type of room such as kitchen lights so he don't install them. He could not explain why they are left out or what similar rooms are.
My guess is you are knowledgeable on the subject so could you explain the codes interpretation of similar rooms and "why" they would leave out just a few areas? Do they think kitchen lights won't arc but dining rooms will for example?
Again I appreciate your comments for nobody else is weighing in.......
08-18-2013, 02:53 PM #5
Its not about the rooms outlets being similar. It is about the actual rooms being similar. Is a kitchen similar to a dinning room ? NO. Is the garage similar to the living room, family room ? NO. Is the laundry room similar to the bedroom, living room, dining room ? NO. The garage and bathroom are not similar to other areas . It has nothing to do with GFCI protection either. They are two completely different items. They stayed away from kitchens to begin with because earlier AFCI's did not work with GFCI receptacles. That has been corrected and the two have been working well together for a couple years now. The acceptance of the AFCI is just like the acceptance of the GFCI was in the 70's. Only required in a few places, then other areas were slowly added until it is like it is today. AFCI's were only required in bedrooms at first, then they added a major part of the home. In the 2014 NEC they are adding kitchens, laundry rooms.
08-18-2013, 03:08 PM #6
08-19-2013, 05:33 AM #7
Thanks for the comments Jack. Your anology of (similar rooms or areas shall) doesn't make sense to me. How would you define similar? You say a Den is not similar to a Kitchen and so forth so what is a den similar too? What is hallway similar to? With you analogy they need to remove the word similar period for no room is like a den and no room is like a parlor, etc.
sim·i·lar
/ˈsimələr/
Adjective
- Having a resemblance in appearance, character, or quantity, without being identical.
- (of figures) Having the same shape, with the same angles and proportions, though of different sizes.
Sounds similar to me............
As far as the GFCI you were talking about in a kitchen is not what I was saying. I was talking lighting, isn't that how AFCI basically started. Lighting being probably the number one reason for fires back in the day. Old brittle wires in ceilings etc. New kitchens in my area may have several can lights besides the large florescent light, pendant light over the island and light over the sink. Wouldn't you think that would of been the ideal place for a AFCI. Yes changes will be coming but that doesn't clear up the grey area in the 2011 code.
