Results 1 to 3 of 3
    brianmiller's Avatar
    brianmiller Guest
    Default pool electrical panel / gas regulator
    Would not the 3ft clearance apply with the gas regulator from the panel?
    DavidSmith's Avatar
    DavidSmith Guest
    Default Re: pool electrical panel / gas regulator
    Quote Originally Posted by brianmiller View Post
    I'd say the panel does not have the proper clearance; also the wall looks like violates the working space clearance , and the gas line is not properly secured.
    David
    Oct 2008
    Tulsa, OK
    Yes, the 3 foot clearance is required from the regulator vent. The vent is designed to be extended with cpvc..
