Thread: Double Tapped Circuits
10-12-2007, 01:09 PM #1
Would like to know if you all call a double tapped circuit even if the one of the doubled up circuits is only going to a doorbell transformer.I have had a few electricians tell I'm not justified in making this call.
10-12-2007, 01:13 PM #2
Re: Double Tapped Circuits
10-12-2007, 01:54 PM #3
10-12-2007, 02:16 PM #4
Ditto above two...
The questions to be answered are;
1) are the breakers rated for two conductors?
and
2) What kind of connection do you think is being make at the point of attachment? My point being that when you have two conductors under the same lug, more than likely there is a potential issue with the point of contacts for both conductors, if not rated for such an installation.
rr
10-12-2007, 03:28 PM #5
Door bell transformers --I see it so much (90%) that I write it up but do not discuss it. New homes--the AHJ must see it and pass ? on it. Door bell transformers are usually hung off of the (outside) the box. Go Sox and then Go Pats.
10-12-2007, 06:10 PM #6
