Results 1 to 3 of 3
    brianmiller's Avatar
    brianmiller Guest
    Default GEC splice in panel
    GEC was spliced in the panel with a splice connector. GECs can't be spliced, correct?
    Aug 2008
    Default Re: GEC splice in panel
    If spliced the splice must be irreversible, otherwise it needs to be continuous. A thermal weld is also allowed.
    Jan 2014
    India
    I want to suggest for GEC splice. Firstly, you can replace splice with a single crimped connector. A single irreversible compression connection has a strong opinion for proper splice.
    Thanking you..
    Epackpolymers.com
