Results 1 to 10 of 10
    Jun 2009
    Nashville, Tennessee
    Default Saw on Face Book ?????
    Saw this on face book on ways to save space. Would this be proper???
    Default Re: Saw on Face Book ?????
    Only if that is one of those fake outlets which is really a small safe in the wall.
    Not if that is a real electrical receptacle, with a box, and wired properly.
    As Jerry noted, it ain't going to work! Just the movement alone from opening and closing the drawer would cause haviock with the connections, etc.
    Quote Originally Posted by Jim Abram View Post
    Without seeing the wiring it is hard to determine if the pictured device is proper.
    There are a number of ways that this can be installed in compliance with regulations.
    There is also a patent on a UL approved drawer receptacle device .
    Jim, could you share how the movement of the power cable is handled with the receptacle that is shown? Wouldn't the movement of the cable weaken the connections and lead to a possible short or worse? Other than using a listed system what would you do?
    I have seen this in homes before, but this is not what is in the picture from what I can tell
    http://www.dockingdrawer.com/sites/d...Literature.pdf Randy, this would be what you are looking for....
    Jun 2009
    Seeing the one Scott posted makes sense. What bothers me is that they show this as ways to save space in your kitchen and now these DIY people will install with out proper wiring harness. One more thing for us to keep a lookout for.....
    - - - Updated - - -
    Knoxville, TN
    I'm not saying that its right, but there are many light fixtures that have a lot of movement built in.
    Work table lights for one.
    Quote Originally Posted by Kevin Wood View Post
    Jim this not the same. I can see how that would work as the outlet is attached to the cabinet not the drawer itself. No different then plugging in a 3 way and viola you have power to the outlet or device.
    Kevin,
    You are correct. Pay little or no attention to what the other says, but you have most likely figured that out by now.
    I adjusted the brightness and contrast of the original photo to show what I saw behind the drawer - a coiled up cord.
    Good one for the back of the knife drawer.
    I suppose the flexible cord coils itself neatly every time you close the drawer?
    Can't designer people find better ways instead of always trying to make things worse?
    Mbrooke's Avatar
    Mbrooke Guest
    Ive seen it before. they are popular in some places. Theory is a hair dryer gets plugged in or curler and no need to drape cords over the sink or plug/unplug.
    On down side I guess would be if someone accidently left a hair curler on or was to come on spontaneously.
    Those when done right have a flexible cord, or, in theory a power rail.
    Jul 2010
    Eatonville, WA
    Great Idea...
    I would add a gas line and sewer line for full convenience.
    Glenn Cummings
    Eatonville, WA.
