Results 1 to 20 of 20
04-11-2014, 08:07 PM #1
Another fuse panel to kick around
Check it out. 100 amp cartridge fuses, with a nice disconnect switch and the correct fuses installed, 1960 house.
What's your comment to the client?
04-12-2014, 03:44 AM #2
Re: Another fuse panel to kick around
Did you really have to ask?
I would inform client to check with insurance company for coverage if the fusing, wiring and everything else is okay.
04-12-2014, 05:47 AM #3
Multiple neutrals under a terminal
Bare copper ground does not look like it's connected.
At the top of the right fuse block, looks like there is an unfused wire connected to the feed.
04-12-2014, 09:49 AM #4
The multiples were allowed IMO. Otherwise the label would prohibit it, I think.
The bare ground is a bonding conductor for something no longer there, loops around, yes, end not terminated, but secured to the box with a cable clamp.
I did call for the panel grounding to be checked, for reason of the picture below, abandoned water pipe, still in use as the grounding rod.
But what about the 100 amp fuse panel service?
04-12-2014, 01:26 PM #5
04-12-2014, 02:10 PM #6
The 100 amp is now the minimum recommended service for my area by electrical authority fwiw.
04-12-2014, 04:15 PM #7
Changing peoples view of the world one panel at a time...............
04-12-2014, 04:22 PM #8
Can say that they have not had many problems since there are only two newer fuses installed. The glass ones are harder to come by in recent years and could be original.
04-12-2014, 05:08 PM #9
Fuses are not hard to find ( photo could indicate a stock pile of replacements are kept on hand whilst resupply is headed in on FEDEX Truck.)
Lot of 5 Royal Crystal 20A Screw Edison Base Fuses 20 Amp | eBay
Last edited by Billy Stephens; 04-12-2014 at 06:50 PM. Reason: changed link address
04-12-2014, 08:49 PM #10
Those are 20's. For the correct 15 amp fuse, he'd have to go to HD.
Leviton | Fuse P Rated 15 Amp | Home Depot Canada
04-13-2014, 05:31 AM #11
04-13-2014, 06:09 AM #12
04-13-2014, 06:22 AM #13
04-13-2014, 06:52 AM #14
How's this?
" Because a replacement fuse will cost you $6 plus tax, and you have jars and piggy banks full of pennies, to avoid the temptation to use them as fuses, I recommend you spend those pennies on a new breaker panel for safety."
04-13-2014, 09:24 AM #15
04-13-2014, 11:42 AM #16
04-13-2014, 04:43 PM #17
If the house does not have need for many circuits, then I would tell them that the panel is functional and probably safer than many old circuit breaker panels. Unless their insurance company or mortgage company requires it to be replaced, then not an immediate need. I do recommend replacing the fuses with Type S fuses.
04-13-2014, 05:43 PM #18
04-14-2014, 02:54 AM #19
04-14-2014, 05:04 AM #20
Going back to John's OP, I would advise the client to call his Insurance Agent to confirm my opinion that the house would not pass a 4 Point Inspection (in Florida) and in all likelihood the panel would need to be changed out.
