04-14-2014, 12:26 PM #1
04-14-2014, 01:30 PM #2
04-14-2014, 03:11 PM #3
Re: Electric Water Heater Clearance (Illinois)
A 24" water heater will not fit thru an opening for a 24" door.
04-14-2014, 03:32 PM #4
Don't forget you should have a drain pan with associated drain as well as the TPR drain. This is not much of an issue for basement or crawl space foundations but requires planning for a slab foundation.
04-14-2014, 07:57 PM #5
I had to replace a closet water heater recently. A standard 40 gal tank was 22". I had to buy the 20" tank and paid almost double for it, the Space Saver.
