08-04-2014, 10:08 AM #1
Habitable space lighting requirements, switched lights.
Does anyone know when it was first required that you need a switched light in a room. I see the 210.70 first shows in 1981 NEC but was there another requirement that predates this?
Don Hester
NCW Home Inspections, LLC
08-04-2014, 02:35 PM #2
Re: Habitable space lighting requirements, switched lights.
08-04-2014, 04:09 PM #3
Jerry, Thank you so much. I have a gap in my code books there. Looks like I need a 75 code book
Don Hester
08-05-2014, 02:55 PM #4
Just a side comment. The requirement is for a switch controlled lighting outlet, not an actual fixture.
08-05-2014, 03:15 PM #5
Right, for a wall switch controlled lighting outlet
- From the 1975 NEC
- - 210-26. Lighting Outlets Required. Lighting outlets shall be installed where specified in (a) and (b) below:
- - - (a) Dwelling-Type Occupancies. At least one wall switch controlled lighting outlet shall be installed in every habitable room; in hallways, stairways, and attached garages; and at outdoor entrances.
- - - - - At least one lighting outlet shall be installed in an attic, underfloor space, utility room and basement where used for storage or containing equipment requiring servicing.
- - - - Exception No. 1: In habitable rooms, other than kitchens or bathrooms, one or more receptacles controlled by a wall switch shall be permitted in lieu of lighting outlets.
- - - - Exception No. 2: In hallways, stairways, and at outdoor entrances remote, central, or automatic control of lighting shall be permitted.
- - - (b) Guest Rooms. At least one wall switch controlled lighting outlet or wall switch controlled receptacle shall be installed in guest rooms in hotels, motels, or similar occupancies.
08-05-2014, 04:52 PM #6
Jim, Good point and correct. I know sometimes when I ask some questions that I am being a bit loose with terminology/definition.
Don Hester
