    Sep 2008
    so so, California
    Default AFCI receptacles
    When receptacles are changed out in existing house, those new plugs must go in as AFCI or AFCI protected in accordance with 406.4(D)?
    Side note... I just had an inspection at my personal house and the inspector said no, only recommended unless new construction. That contradicts what Holt said..
    NEC 2011 AFCI Receptacle Replacements - 406.4D - YouTube
    Mar 2013
    Md and or PA
    Default Re: AFCI receptacles
    What code edition being enforced 2008,2011,2014 ?
    Did they jurisdiction make a local amendment about this?
    In the 2011 NEC the AFCI requirement for receptacle replacement came into effect January 1 2014
    Sep 2008
    so so, California
    Quote Originally Posted by jack davenport View Post
    Yea, should have thought of that...
    Feb 2010
    Wenatchee Wa
    Marc,
    Here (Washington St) we are now under the 2014 NEC. And if you replace a receptacle in an area that is required to be AFCI/GFCI protected they are to replace with the appropriate protection which in some cases is both AFCI and GFCI (and tamper proof if applicable ; ).
    Also this is a modification of the circuit that needs to be permitted, FYI.
    I am telling my clients that any room that is not a bathroom or attached garage now needs AFCI protection.
    Here is a graphic I made. Everyone feel free to use.
    Don Hester
    NCW Home Inspections, LLC
    Sep 2008
    so so, California
    We haven't adopted 2014 yet. I like the image, thanks for that.
    Quote Originally Posted by Don Hester View Post
    Marc,
