Results 1 to 3 of 3
    Sep 2008
    so so, California
    Default 200.7 Using white wire as ungrounded conductor
    Just trying to understand this section. Can a white wire be used as an ungrounded conductor and if so where/when?
    Mar 2009
    Colorado Front Range
    Default Re: 200.7 Using white wire as ungrounded conductor
    This is pretty self explanatory. White and gray wires in a cable can be re-identified and used as an ungrounded conductor. Note this applies only to cables - white and gray wires in a conduit have to be used as grounded conductors.
    The most common example is when a 2 conductor cable is used as a switch leg, the white is remarked and used as the supply to the switch (in this instance, the remarked white can only serve as a switch supply, it can't be used as the feed to a fixture - the idea being a fixture can't be supplied by two white wires)
    Sep 2008
    so so, California
    Got it thanks BK
