Thread: sub panel
02-27-2015, 05:33 PM #1
sub panel
This is a panel inside the trailer, that is surrounded by additions. Main service disconnect is outside. I know this is not right, but want to hear from you.
03-06-2015, 07:36 PM #2
Re: sub panel
I'm not sure what "surrounded by additions" is meant to convey. All grounds should terminate on the grounding bar, including the incoming grounding conductor and the auxiliary grounding electrode conductor(GEC). The latter has no place in a distribution panel unless the service is wa-ay far away, very unusual and IMO requiring an AHJ consult, if not formal sign-off, in the case of a service disconnect alone. If it is the service GEC rather than an auxiliary GEC, it belongs in the service itself, meaning with the disconnect.
03-06-2015, 08:16 PM #3
Re: sub panel
In 'addition' to what David said,
The mobile home has additions, so we assume circuits have been added or existing circuits have been extended. I think I see Al branch circuits, so the original fixtures need to be checked for corrosion and those additions need to be checked by a qualified electrician.
We have strict rules about adding to mobile electrical here. A licensed electrician issues an inspection certificate before the home changes hands. Why, because if the home ever catches fire, it can burn to the ground in 10 minutes or less.
03-06-2015, 09:16 PM #4
Re: sub panel
03-07-2015, 07:16 AM #5
Re: sub panel
David,
the main panel is not attached to the building, is about 40 feet away. The trailer is surrounded by additions.
03-07-2015, 11:22 AM #6
Re: sub panel
03-07-2015, 05:00 PM #7
Re: sub panel
No, it is not in a park, It is a 1960 vintage trailer on a large wooded lot in the back country. Big ole ramshackle of a place with all the additions and porches. The electrical was in surprising good shape, most all of it upgraded, with the exceptions noted in the picture.
