03-31-2015, 09:51 AM #1
Square D - 3 grounds under one terminal
I have started seeing Square D panels that are allowing up to 3 grounds per terminal screw. Its been limited to 2 for several years so I thought I would throw this out just in case some have not noted the change before now. Note that mixed wire size combinations are not shown.
03-31-2015, 10:54 PM #2
Re: Square D - 3 grounds under one terminal
Thanks for sharing.
- - - Updated - - -
Thanks for sharing.
Don Hester
NCW Home Inspections, LLC
04-05-2015, 08:09 AM #3
I noticed that also have only seen it in the new square D that has the plug in ability for the AFCI and GFCI breakers by doing that they eliminated every third screw on the grounding/grounded bar so I guess they had to make up for the lack of holes by increasing the number of conductors allowed you can watch the video about them here. Square D QO 20 Amp Single-Pole Plug-On Neutral CAFCI Circuit Breaker-QO120PCAFI - The Home Depot
04-05-2015, 08:55 AM #4
Does that label say a maximum of 80 circuits is allowed ??
04-05-2015, 09:03 AM #5
Yes 42 space maximum has been eliminated from the code it now is as marked from manufacturer so as many as they test it with to get their listing
