Thread: panel
    Mar 2011
    Corinth, NY
    Default panel
    Wondered if anyone would comment on this panel. It is split bus,,, There is a dryer that is hooked to 2 single pull breakers, one on either side, obviously not tied together. Never seen this one before. It is a ge panel.
    Default Re: panel
    Quote Originally Posted by Russell Melville View Post
    Photos?
    Even without photos, though, that is not permitted. So, with photos, the end result would likely only get worse ... if there is a worse than 'that is not permitted' ... maybe it could be worse as in 'how fast would that burn the structure down' ... ... wait, that would be a
    Mar 2011
    Corinth, NY
    Default Re: panel
    I think i got the pics this time.
    Mar 2011
    Corinth, NY
    Default Re: panel
    i don't understand why you can't see them, i see the photos on my end.
    Default Re: panel
    Russell,
    Kevin isn't saying he can't see the photos, just that (and as I said) from your description photos are not needed to state what you described was wrong.
    Your photos simply confirmed your description and that it is wrong.
    Mar 2011
    Corinth, NY
    Default Re: panel
    Got it, and thought that might be the case, if were not for Jerry's first post. And I would have expected more commentary on this, i guess. Like, why wire the dryer that way?
    Thanks for the clarification.
Tags for this Thread
