    Feb 2015
    Wisconsin
    Default Lightning arrestor connected to Main Terminals
    The main panel had a lightning arrestor (or arrester - seems there is no consensus) installed. The two conductors for it were installed in the terminals of the service disconnect, along with the service conductors. My first reaction was that, "Whoa, you cannot double-tap there". Then I thought well, maybe it offers the best protection right there. Then I thought it still seems to violate the basic principle that when the service disconnect is off, everything should be disconnected. Is it acceptable to connect this thing here?
    On a side note - do these things actually work?
    Default Re: Lightning arrestor connected to Main Terminals
    Quote Originally Posted by Roger Kautz View Post
    Quote Originally Posted by Kevin Wood View Post
    Yes!
    The "Yes!" is to which?
    "Is it acceptable to connect this thing here?"
    NO!
    "On a side note - do these things actually work?"
    Sort of ... ONE TIME as that is all they are made for.
    Has it already severed its purpose?
    Hard to tell, some have red LED lights which are supposed to tell if it is still good or not. Others do not have lights, they just explode when hit (they are not intended to explode, it just happens), some swell up (and don't explode, that is what is intended), some simply don't work (and you don't know if they are good or not).
    Easy to get the wrong message as the US think different.
    Easy to get the wrong message when TWO questions are asked and the answer provided is simply ... "Yes!"
    "Yes!" ... what?
    Yes to the first question?
    Yes to the second question?
    Yes to what is on your mind?
    Yes ... very easy to get the wrong message when the US likes to know what the answer is pertaining to ... I would THINK that US'NS (all "us'ns", which is similar to "yall", which is short for "y'all", which is short for "you all", or if you be from some parts it would be "youse" or "youse guys") 'cept that "us'ns" includes the speaker ...
    Mar 2009
    Colorado Front Range
    [QUOTE=Jerry Peck;260616
    'cept that "us'ns" includes the speaker ... [/QUOTE]
    That there would be "we'uns". "We-uns" is the group associated with the speaker and the speaker.
    Y'all is the group associated with the person the speaker is talking to, but may include all the we'uns group but the speaker.
    They'uns is a group separate from the speaker and his group and separate from the person the speaker is talking to and his group
    Aug 2011
    I put one on my system, recently. The directions specifically called for double lugging on the breakers (but not on the main) and explained that it was permitted for this use. The two electricians that I've discussed this with have installed similar devices the same way.
    Hopefully, I never find out if it works (worked). I'm a little dubious, but my research says they do.
    They do it that way because it is to much trouble and more expensive to do it correctly.
    There is no code or listing exemption which allows doing that.
    Aug 2011
    I just re-read the directions and I am correcting myself. The directions do not specify any kind of double lugging.
Tags for this Thread
