Results 1 to 10 of 10
Thread: Two Main Breakers
03-22-2016, 01:14 PM #1
Two Main Breakers
I'm writing up an inspection for a new home that has two main breakers. One below the meter at the front of the property (200 amp), and another one at the front of the garage (200 amp). These are both separate from the main panel and subpanel in the garage.
I've never seen two mains in series before. Is this acceptable? Thanks in advance.
03-22-2016, 06:12 PM #2
Re: Two Main Breakers
Yes if done properly.
I'll let the master sparky Jerry answer further.
03-22-2016, 06:28 PM #3
It would help if you recognized the service at the pole near the meter. The others are just panels. The breakers are the required disconnects.
03-22-2016, 06:35 PM #4
To clarify: The above main is on a pole or pedestal, right?
If so, then that one is the main service disconnect and that is the service equipment.
If my assessment of the panel by the meter is not correct, let me know.
If my assessment is correct, look at the panel at the meter as the service equipment (and report it as such) because that is what it is.
Which leaves you with just one main disconnect (the one at the meter).
Additional information will be required to complete this, but we need to clarify the above first.
03-22-2016, 07:15 PM #5
Pictures might help.
03-23-2016, 06:07 AM #6
03-23-2016, 06:14 PM #7
Thanks everyone, that does help.
Jerry that is correct, meter and service equipment on a pole. Instead of running the overhead to the home they ran it to a pole with the service equipment, with a buried line to the front of the home.
03-24-2016, 05:19 AM #8
03-24-2016, 07:37 AM #9
I agree with Jerry on naming "Service Equipment". Could this also be a 400amp service?
Typically the service equipment will be grouped.
Don Hester
NCW Home Inspections, LLC
03-24-2016, 07:44 AM #10
