    Default Low voltage light power
    I need a little help. I found two low voltage power supplies inside walls plugged into an outlet which was covered by a plastic removable cover.
    It has access but I can't believe this would be acceptable to the local AHJ.
    Obviously the outlet can't be just hanging inside the wall, needs attachment to the structure. What else do you see as code violations? I can't see a transformer being ok in this location.
    Aug 2008
    Default Re: Low voltage light power
    Besides the box not secured to the structure, I doubt the LV cables are listed for in wall usage.
    Aug 2013
    Texas
    looks like a rigged job. probably hooked up to an extension cord or similar in the attic
    Mar 2012
    Wisconsin
    Hi Jim
    Can you give an example of a LV cable that is not for in wall usage? I see telephone wire, intercom wire, Cat 5, speaker wire, LV lighting, and the list goes on. Thanks.
    Quote Originally Posted by Mike Borchardt View Post
    Hi Jim
    Not Jim, but the cable which comes attached to those plug-in low voltage transformers, and those low voltage transformers themselves, are intended for use outside walls.
    Mar 2012
    Wisconsin
    No mention of the transformers, but I agree they cannot be in the wall. I thought the LV cable was in reference to something other than the wire coming out of the transformer.
    Thanks Jerry
    - - - Updated - - -
    Thanks Jerry
Tags for this Thread
