Thread: Tube lights
    Ron Bishop's Avatar
    Ron Bishop Guest
    Default Tube lights
    Is anyone aware of a safety hazard involving the use of tube lighting?
    Default Re: Tube lights
    They are just like Christmas lights. I'm seeing more and more of them used as accent up lighting in homes. They are plugging them into outlets set in the area that they are lighting.
    Those rope lights are, as Scott said, turning up more often.
    They are DIY lights in most cases and are typically installed incorrectly, not just the electrical extension cord, but, in the case in the photo - those are creating a trip and fall hazard on that tread.
    Is that an orange extension cord, or unprotected NM cable? Does not really matter, NEITHER is allowed there like that. Also looks like white zip cord (lamp cord) along the stringer too.
    I guess having a trip and fall hazard next to two self-igniters is the new in thing?
    Ron Bishop's Avatar
    Ron Bishop Guest
    ay caramba....
    I've always figured these to be decorative/temporary lights and have not given much attention to them. Not sure if this is the appropriate approach but it's my current M.O. - subject to chance.
    Eric,
    Once they are "permanently attached", i.e., "stapled" or otherwise secured in place ...
    They are no longer 'temporary', they are permanent and required permanent wiring.
    The one in the photo is stapled in place.
    Regardless, though, if that were laying on the steps and 'not' stapled in place, it would still be a trip hazard.
    Shannon Guinn's Avatar
    Shannon Guinn Guest
    Eric,
    And unless they are plugged into a GFCI it would be a shock hazard as well.
