Thread: Unknown Gizmo?
    St. Louis, Mo. area.
    Default Unknown Gizmo?
    One of these was low on the wall of some of the interior areas in today's inspection of a higher end condo. Does anyone know what it is? My clients are asking me, and I told them I didn't know, but that I had access to some of the best home inspection experts who would probably be able to tell me what it is. I was of course talking about the people on this forum. Thanks in advance for your help in identifying this thing for my clients.
    Oct 2010
    MONTREAL QUEBEC-CANADA
    Default Re: Unknown Gizmo?
    High on ceilings or walls is typically/usually smoke/fire/co detectors.
    Just guessing but, being positioned low on a wall might indicate an atmospheric sensor. IE: sniffer. Temperature/gas/vapor/oxygen sensor would be my best guess.
    Refer to condo association/syndicate or building's maintenance personnel.
    The place had regular smoke detectors on the ceilings. We were speculating either part of the security system, or possibly some kind of pest deterrent device.
    Quote Originally Posted by Michael Chambers View Post
    Looks like a speaker for an alarm.
    That is standard wall outlet size, although I guess it could be something like that. They're miniaturizing everything else.
    Could be a cover for speaker or coax wiring. Newer construction has a lot of pre-wired distribution cables to different rooms. I think I would have taken out my phillips screwdriver and removed the cover to see what was behind the plate.
    Quote Originally Posted by Gary Burnett View Post
    Well, although I've been known to do just that, the one I took the photos of was located in a hallway, not where you'd normally want speaker or coax wiring.
    Mar 2013
    Md and or PA
    low to the floor -- hmmm
    Stabbing in the dark here .................... ( pun intended)
    low wattage night light ??
