Results 1 to 3 of 3
    Clay White's Avatar
    Clay White Guest
    Default Service Equipment Panel for Condos
    Default Re: Service Equipment Panel for Condos
    I inspect them. None of the ones I've seen could be considered common.
    Jon Randolph's Avatar
    Jon Randolph Guest
    FWIW,
    I inspect a condo no different than I do a detached home. Even though the association may be responsible for the exterior there are many items that, if left unchanged/unrepaired, can negatively affect the part of the structure that the owner is responsible for.
