    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Receptacle for refrigerator
    Default Re: Receptacle for refrigerator
    "Should be", but if it is an old house with two wire non-grounding type receptacles (i.e., knob and tube, old 2-wire NM cable, 2-wire BX, etc.), there will be not ground available at the receptacle outlet.
    Tim Moreira's Avatar
    Tim Moreira Guest
    If you added a GFCI outlet there, wouldn't that solve the problem?
    Quote Originally Posted by Tim Moreira View Post
    Not really, it would not "solve" the no ground.
    It would, however, provide an extra margin of safety for the users of the refrigerator. Just like GFCIs do for non-grounded circuits.
    Not required, but it would be a good idea.
    I know, someone is going to jump in here and say 'But ... but ... but you don't want a refrigerator on a GFCI, all that food could spoil if the GFCI trips off.
    Yep, it could, but I'd rather have all that spoiled food than a dead body laying next to a 'hot' refrigerator, wouldn't you?
    Tim Moreira Guest
    That was kinda my thought too. Food is easier to replace.
    Unless, of course, you are the 'dead body' next to the refrigerator, then its rather difficult for you to replace the food.
    Fuquay Varina, NC
    Thumbs up Re: Receptacle for refrigerator
    I think we should market "live" refrigerators. Think of all the weight your significant other would loose if they where zapped every time they went for the fridge.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
