Thread: Flex Conduit
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Flex Conduit
    Default Re: Flex Conduit
    Well ... it *is* "allowed", but no self-respecting electrician would install that for that purpose.
    None of the electricians commented on the bend being too sharp at the bottom where it comes out and then goes up?
    The bottom part, being as it 'does not' go into the ground, but just enters the crawlspace, is "okay", but again, no self-respecting electrician would use it for that.
    Looks to me like somebody went down to the local Big Box store and bought a roll of FNMC and figured it would the the easiest and cheapest way to get from point A to point B. I think they goofed on "the cheapest way", but it probably was the "easiest way".
    But it really is not 'to' the service equipment, it is 'from' the service equipment to the panel(s).
    See that power company lockout device? Apparently had problems with, or suspicions of, people stealing power in the past.
    Tim Moreira's Avatar
    Tim Moreira Guest
    The first thing that caught my eye was that excessive bend.
    First thought was, not a *professional* install.
    K Robertson's Avatar
    K Robertson Guest
    Quote Originally Posted by Tim Moreira View Post
    If nothing else (which I'm not saying there would be nothing else) I would call out that bend. Then I'd list the material as evidence of amature install.
