Results 1 to 9 of 9
Thread: Hot Shower
    Donald Merritt's Avatar
    Donald Merritt Guest
    Default Hot Shower
    I found these electrical panels behind a mirror hanging on the wall in a vacant house. Wondered why someone would leave the mirror.
    Attached Files Attached Files
    Default Re: Hot Shower
    Mirrors are common in the bathroom.
    Question is why would someone install the panels in a bathroom?
    Connecticut
    That's easy, That was an added mother in-law suite. Can you blame him?
    Now the question is, did it work?
    Maybe those subpanels were fead by a GFCI fuse from the main panel.
    Richard Abrams's Avatar
    Richard Abrams Guest
    Cool Re: Hot Shower
    Panels were probably there first before the room was made into a bathroom. Bad Homeowner job.
    John Steinke's Avatar
    John Steinke Guest
    While, according to current rules, you are not allowed to have a panel in the bathroom, I don't know when this requirement was introduced. I seem to recall it being in the late 60's.
    If my memory is correct, considering the age of the equipment, this very well might be a legal arrangement.
    Also please note that ... a bathroom is not a bathroom unless there is a sink in there. If this were a stand-alone shower room, even the current NEC rule would not apply.
    One might try to extend switch and receptacle rules to keep the panel outside the actual shower enclosure .... the goal is worthy, but the logic a bit weak.
    Let's face it: some things are so basic as to be self-evident, and one seldom sees a rule against them. For example, I'm pretty sure there's no law specifically against stepping in front of a speeding locomotive.
    In a situation like this, the 'enforcement' comes in an indirect way, as prospective buyers use this 'improvement' to LOWER the value of the property.
    The Treasure Coast
    I would suspect that there is a sink there. I see in the bottom of the picture what appears to be either a soap dish or a toothbrush holder.
    I would write it up as a safety issue. Having a fuse panel that close to the shower can't be good. Not to mention, they may not be able to get homeowners insurance due to the presence of fuses and, that most likely, the shower/bathroom wasn't permitted.
    Eric Van De Ven Magnum Inspections Inc. (772) 214-9929
    www.magnuminspections.com
    Well said. "some things are so basic as to be self-evident, and one seldom sees a rule against them"
    Codes do not address "stupidity".
    As is frequently pointed out ... HIs "are not code inspectors", which is a positive in that as, *not being* a code inspector allows the HI to call out "stupid" things which are "self-evident" and for which there is no rule against them.
    Jeff Remas's Avatar
    Jeff Remas Guest
    I don't see a problem. This makes it very convenient to change a fuse if one blows while you are taking a shower
