Results 1 to 12 of 12
Thread: Opinions Wanted
    New York
    Default Opinions Wanted
    I came across this set up today. I feel that the 2x4 is too flimsey to attach to. Am I making a big deal out of nothing?
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Opinions Wanted
    It looks OK from what i can see.
    Whats the span of that ridge? it look like a 2x12
    comp or tile roof?
    Is that kicker off a center wall ?
    do you have a snow load there?
    Best
    Ron
    New York
    Hi Ron,
    I really got the impression that the 2x4's were remnants of framing out the roof. The rafters are 2x8's, the span is about 10'. Composition roofing. Are you thinking they are more than temp supports. If so, I certainly feel the way they are attached is flimsy to say the least.
    I wouldn't have called it out unless the 2x was loose.... just my own opinion though.
    New York
    Brandon,
    What do you feel about the issues Ron brought up regarding the span? I never felt the structure was underbuilt and as I stated, I believe the braces are remnants of the framing process.
    Do you think I am off base?
    Connecticut
    I think those posts belong under the hip in that position and should be left there.
    James Duffin's Avatar
    James Duffin Guest
    It looks like to me it was installed by the electrician to mount the light and receptacle to.
    I think that's a very nicely framed roof and unless you're an engineer and have a set of load specs in front of you, you'd be way off base commenting on it.
    As for mounting the electrical stuff to the 2X4 I agree that as long as it's not loose I wouldn't comment.
    Brandon,
    Steven,
    Seeing as how that is just a 2x, I can't see how it was designed to carry any of the load. Where's the New York Brandon when you need him?
    Cape Cod, Massachusetts
    The verticle 2x's look like temp support when framed. The hip roof and ridge vent detail do not require support at these locations.
    Brandon Chew's Avatar
    Brandon Chew Guest
    The vertical supports under the ridge are not needed if the ceiling joists are properly functioning as rafter ties (which keep the roof from flattening and the walls from pushing out). They were likely installed while the roof was framed in order to hold the ridge board in place until it was supported by the rafters. They are frequently left in place after construction is completed.
    I wouldn't comment on the one with the light and receptacle attached to to it unless I felt that it might come loose if bumped.
    Brandon Chew Guest
    With my kids on a school trip to Mystic Aquarium.
