03-27-2008, 01:36 PM #1
Stranded conductor split under two terminal screws?
I came across a stranded conductor (large diameter) on the bus bar with the strands split under two terminal screws. I have never seen this before. Does anyone have any information on this?
Thank You
03-27-2008, 01:53 PM #2
Re: Stranded conductor split under two terminal screws?
I've seen it a few times. It's not right, of course. Should terminate on a single properly sized lug.
03-27-2008, 02:32 PM #3
Thanks. It didn't look right and just wanted to be sure before I reported on it.
03-27-2008, 02:41 PM #4
Previous thread:
Grounding conductor split to fit into two lugs??? - Home Inspection & Home Inspector Services For Inspections and Inspectors
It frightened me when you accepted my word for it. At least the old thread has the JP stamp on it.
