Thread: Ground wires
04-08-2008, 09:30 PM #1
Ground wires
Thoughts guys. Here are two separate ground wires pigtailed on a connector and then connected to the ground bar. Contractor says it is correct. I say no. Who is right.
04-08-2008, 09:42 PM #2
Re: Ground wires
That's always been the preferred method with load conductors as opposed to a double tapped breaker. Assuming it doesn't overload the circuit (a grand assumption, I realize).
Are there no more open slots on the ground bus? Yes, it would be better to have each wire attached to the bus but I can't say it's 'wrong' the way it's done.
I'd never call it out.... it's approaching splitting hairs.... jmo
04-09-2008, 05:55 AM #3
Re: Ground wires
That works well because the overcurrent device is in the circuit, thus, regardless how many #12 wires you have, you are protected at 20 amps maximum though the total of them, and through the one of them.
Not a problem there.
Most ground bars now allow up to two (some even three, but only is so stated) ground wires in the same terminal hole if the same size and same material (copper).
I'd let them 'do it right' and eliminate the wire nut. *IF* the wire nut was only used to allow each to be made longer, that would not be a problem, but putting two into one 'could be'.
04-09-2008, 09:16 AM #4
Re: Ground wires
Electrician is right This junction is made in an approved junction box.
