Results 1 to 13 of 13
    Tampa, Fl
    Default knob and tube removal
    Am I correct that all knob and tube is required to be removed at time of replacement? Does anyone have a code reference for this? Inspected a house today that had abandoned k&t still in place, It was replaced about a year ago, and I am thinking the electrical contractor that did the work might be required to come back and remove it. Thanks.
    Default Re: knob and tube removal
    Quote Originally Posted by Matthew Barnicle View Post
    I'm not aware of any requirement. Yes, it would be nice but you could never get rid of it all unless you tear out he walls, etc.
    What would it hurt if it is left in place? I see nothing wrong if it is not live and has been replaced modern NM lines..
    Fuquay Varina, NC
    Maybe cut the exposed wires off so it's not a tripping hazard in the attic. Mice like to use them to slice there cheese.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Tampa, Fl
    If left in place, you could not determine if it was all deactivated during a cursory home inspection. Clipped wires everywhere with no junction boxes or wire caps. You can only do a sampling with a voltage sniffer, so no way to know if it is all deactivated or maybe some of it was left on a switch even if it is dead. Maybe insurance companies want it all gone. With the price of copper these days, you would think the electrician would be glad to remove it.
    James Duffin's Avatar
    James Duffin Guest
    It seems like if you could see it to remove then there would not be a problem with the K&T being covered....it would be uncovered.
    I tend to agree with Matthew. If present, I note that I cannot verify if all of the K&T has been disconnected/abandoned.
    No requirement to remove it when abandoned ... which makes it oh so easy for a DIYselfer to re-energize it later ... with potentially deadly results.
    Randy Clayton's Avatar
    Randy Clayton Guest
    I dont know of any requirement of removal; but was quite surprised that if it was installed correctly is ok by the code check manuals!! See the back of the book they have pics and everything.
    Quote Originally Posted by Randy Clayton View Post
    FYI, Douglas Hansen has K&T in his home, if I recall it is in his kitchen area!
    Randy Clayton Guest
    Scott, you know the last three homes I've inspected that knob & tube wire was replaced there was always one circuit usually the front porch still with the original wire????
    John Steinke's Avatar
    John Steinke Guest
    There is no such code requirement. While there are code requirements to remove abandoned data, phone, and CATV wires ... there is no general requirement for removing abandoned power wiring.
    No kidding? Why would that be?
    Actually, John is mostly correct about that, but the alternative is to label those for future use rather than abandon them.
    It is quite easy to mix up Class II wires and use them for other uses/systems/etc., so the accessible portion is to be removed. Yeah, its never done.
    From the NEC.
    - 725.25 Abandoned Cables.
    - - The accessible portion of abandoned Class 2, Class 3, and PLTC cables shall be removed. Where cables are identified for future use with a tag, the tag shall be of sufficient durability to withstand the environment involved.
