Results 1 to 2 of 2
    Eric Laney's Avatar
    Eric Laney Guest
    Default Here's where you plug in the sump pump
    Inside the sump! This way when the water rises (pipes clog, motors fail) it enters the electrical receptacle and automatically shuts off the pump, right?
    Default Re: Here's where you plug in the sump pump
    Ingenious. Maybe they should get a battery back-up system, and put the battery in the bottom of the sump!
