Results 1 to 2 of 2
    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default non service panel / insulated grounds
    if a couple of ground wires are connected with the neutrals, but the grounds wires are coated in plastic, is that still a problem?
    Default Re: non service panel / insulated grounds
    Grounds are connected together in the service equipment panel only. Insulated or not, if it is not SE, then the grounds need to be isolated. It is not a matter of insulating, it is a matter of the path of the current.
