Results 1 to 9 of 9
    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default bulldog push matic
    I believe this is fused? again i did not open it. Any history of concerns with this type main, other than being 45 + yrs old.
    Aaron Miller's Avatar
    Aaron Miller Guest
    Default Re: bulldog push matic
    In a word, obsolete.
    According to the NAHB Study of Life Expectancy of Home Components electrical "accessories" are rated at 10+ years. I would venture to say that 45 years is beyond this unit's service life.
    Aaron
    Quote Originally Posted by Jerome W. Young View Post
    It is a breaker and not a fuse. As Aron said it is old. Bulldog pushmatics have very few problems, except that they are old.
    Chicago
    Red face Re: bulldog push matic
    Hi Scott,
    I'll bet ya a steak at Gibson's (next time you are in Chicago) that this a fused (or un-fused) disconnect switch but not a breaker.
    Corey
    Quote Originally Posted by Corey Friedman View Post
    Hi Scott,
    Corey
    Corey,
    Scott will be buying ... select the thickest cut they have.
    Randy Clayton's Avatar
    Randy Clayton Guest
    I'm going with Corey on this one. You open that box and you will find fuses (i could not tell from that pic the size or phase type) But that is strictlley a disconnect box with fuses inside!!!!!
    Corey, I'll be in Chicago next week. I' be in town from the 15th-17th. How's Steak and Shake!
    Chicago
    Thumbs up Re: bulldog push matic
    Steak-n-Shake it is!
    Evan Grugett's Avatar
    Evan Grugett Guest
    This is probably a main switch (the plate reads 100 amps 240 volt) and is not fused. These boxes should really be opened if at all possible and the interior inspected for cable size, cable material on the line and load side, and problem conditions (taps, corrosion, etc..). This is +35 year old equipmentIn these parts licensed electricians say that Bulldog Pushmatic breaker panels are hard to get replacement parts for and so I warn the client on that in my report.
    Evan Grugett
