    Michael Vasquez's Avatar
    Michael Vasquez Guest
    Default GFCI protected outlets
    Did an inspection on a house built in 1984. The exterior, garage, wet bar and bathroom outlets were all protected on one GFCI in the master bath. Is this in need of repair?
    Thank You
    Default Re: GFCI protected outlets
    Typical for the age. The pdf below was posted by someone else (probably JP or Jerry Mc) a couple of times in the past.
    Attached Files Attached Files
    Thanks for the information sheet. What if all the outlets trip on one GFCI, is this in need of repair?
    James Duffin's Avatar
    James Duffin Guest
    It may be any inconvenience but it is not a repair item. To separate them would be an improvement.
    Randy Clayton's Avatar
    Randy Clayton Guest
    as long as its there though may be incoveinet
    Thanks for the replies.
    Gunnar,
    The updated GFCI one. Plus one for AFCIs,
    JP,
    Thank you so much. And here I thought I was already up-to-date.
