    Apr 2007
    Lafayette,Colo
    Default more electirc stuff
    Gonna try this one more time... here's the pic's of the masthead in question....kosher? B
    Default Re: more electric stuff
    Is that a window or door to the left?
    Apr 2007
    Lafayette,Colo
    Default Re: more electirc stuff
    I'ts a window.... I wrote that up as too close... the way they wired the head seems suspect to me... told the client to have the whole electrical service evaluated by an electrician..B
    Healdsburg, CA
    Looks like a minimum 120 volt service?
    Eric Mayberry's Avatar
    Eric Mayberry Guest
    1. Undersized wiring at the weather head.
    2. Spliced connections are improper. Should be a mechanical weld (crimped connection).
    Looks like its gonna get hot when they put juice to it.
    Randy Clayton's Avatar
    Randy Clayton Guest
    Wink Re: more electirc stuff
    This is one write it up sure;but under that tape youll find crimped connections. How ever at that splice back to the pole;is the suppliers discression and will be what it is
    Apr 2007
    Lafayette,Colo
    Actually those are wire nuts with electric tape over... nice huh
