Results 1 to 3 of 3
    Default Outdoor sump pump GFI?
    Sump pump would indicate it's not required if in a basement or crawl space but exterior outlet should be GFI.
    Does the sump pump exclusion from GFI protection apply to an outdoor outlet?
    Default Re: Outdoor sump pump GFCI?
    Matt,
    Sump pumps are not excluded in the basement or crawlspaces either, since 2005.
    Yes, the sump pump requires GFCI protection outdoors too.
    GFCI chart available here: Construction and Litigation Consultants
    Default Re: Outdoor sump pump GFI?
    Thanks JP... I was looking at your chart but just didn't read down far enough
