Results 1 to 9 of 9
    Tampa, FL
    Arrow Results! Ah Ha! Re: El
    Some of you might recall my post of one and perhaps even two weeks past. It was re the wild and wooly case of the HI's home and the same Vaac/trip circuit home of the Hi's neighbors Joe and Lori and family. While I am not 100% certain, I believe that I have cracked this case. Though this determination may be argued to be conjecture on my part according to our very finest legal theorists, it is my position that the evidence is compelling and I am willing to beat up these theorists up should that become necesary.
    The findings of the forensic investigation are these. Hi's home was tested. Joe and Lori's was not. Test protocals were these-a) Open HI's electrical panel box. b) inspect for irregulariites. c) determine circuit which malfuntion had occurred on prior occasions. d) measurure amp/volt draw under normal loads. e) prepare to measure amp/volt draw subsequent to breaker trip/failure on plugging in Hi's same two vaacs. One of two of the Hi's vaacs has a new motor winding and, hence, this portion of testing is, with knowlege aforethought, skewed and contaminated. It seems the HI cannot bear to part with old friends (an Orick over 20 perhaps 25 years of age and not Kirby)
    Results. No unusual current draw/loads prior to switching on Vaac A or B. Vaac A switced postive/on three minute. Nada. Vaac B same. Test over.
    Conclusion-New breakers sometimes need to seek out their their corect carma for loading. Just like all of us, if you will. No safety concern at all. but mointor, dueto dissimilarities of symptoms twixt HI and subject systems. I nwould advise my son or daughter same.
    Tommy Boy
    FABI RPI 0051 LOL FL
    Thanks to all fo all. Best and Only Forensic Minds Worldwide. K? Over and out! Rogers. Thanks con mucho gusto. Yo se ebla pequeno. Esso?? Ques es?? Gracias muchacos!
    Tommy
    Healdsburg, CA
    Default Re: Results! Ah Ha! Re: El
    Very impressive Tom, but I suspect it was not the kind of impression you really wanted to make here?
    What did he say?
    Tampa, FL
    Jerry. Hello. Could you kindly be a bit more specific sir in your response to my post? With all due respect for you, I find it to be somewhat nebulous and if it were more clear, then it might help.
    Isn't nebulous a type of cloud formation?
    Georgetown, KY
    I'm with you Rick.
    Uh, say what?
    Nick,
    You are probably thinking of "Cumulus Clouds": Fair Weather Cumulus Clouds: puffy cotton balls floating in the sky
    "nebulous"
    nebulous
    One entry found.
    nebulous
    Main Entry: neb·u·lous Pronunciation: \ˈne-byə-ləs\ Function: adjective Etymology: Latin nebulosus misty, from nebula Date: 1784 1 : of, relating to, or resembling a nebula : nebular 2 : indistinct, vague — neb·u·lous·ly adverb — neb·u·lous·ness noun
    Just so we will all know what we are talking about!
    Daniel Stone's Avatar
    Daniel Stone Guest
    Ohhh...Nebulous, finish your porridge!
