Results 1 to 3 of 3
    Roni Litmanovic's Avatar
    Roni Litmanovic Guest
    Default Thermal images of AFCI breakers
    Lately, I have found when we do a thermal scan of distribution panels in new condos, ALL of the AFCI breakers inside the panel appear as overheated...Is this normal? Most other breakers appear at normal operating temperature.
    Default Re: Thermal images of AFCI breakers
    Quote Originally Posted by Roni Litmanovic View Post
    Yes.
    AFCI breakers each have a small power supply inside them to run the computer circuits in them, that consumes power, which creates heat. It is that heat which you are seeing on the infrared camera.
    Great Jerry Thanks...
