    Sep 2009
    Twin Cities, Minnesota
    Default Different light switch
    In the picture, the switch on the left controlled the exterior lights on either side of the front door. I hadn't seen a switch like this before and it was really difficult to operate. Anybody know what it's called, or if it does anything special? This is a residential house built in 1971. I recommended having the switch replaced since it was difficult to operate.
    Thanks.
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Southwest US
    Default Re: Different light switch
    it's for an X-10 system, the switch can be operated by a remote control plugged into an outlet in the house.
    Here's more information than you ever wanted;
    X10 (industry standard) - Wikipedia, the free encyclopedia
    Agreed, X-10 switch.
    Sep 2009
    Thanks guys.
    -Jon
    Jon,
    Was the switch difficult to operate (defective mechanism) or did you have a problem because you were not familiar with how it operated ?
    Sep 2009
    It was difficult to operate. I kind of had to push the button in and down a little. Are those switches normally easy to operate, or is there a trick?
    -Jon
    Apr 2014
    California
    Quote Originally Posted by Jon Errickson View Post
    The top part is a push switch and the bottom is a rocker/dimmer, works to create three way where wiring is not available, and to control with all on or all off command.
    - - - Updated - - -
