Old 05-16-2007, 05:17 PM
John Stephenson
Posts: n/a
Electrical cable insulation cover
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Old 05-16-2007, 05:26 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: Electrical cable insulation cover
I was always told to remove it because it was a flammable material from inside the panel.
Old 05-16-2007, 05:59 PM
Jerry Peck's Avatar
With everything else which is wrong in that panel ... I would only mention it in passing, as in ...
Get a QUALIFIED and LICENSED electrical contractor out to correct all the sh*t in this panel, including, but not limited to: (make list, including that item - but that is the least of their problems).
Only I always said it nicer in my reports.
Old 05-16-2007, 07:06 PM
Jerry Peck's Avatar
Quote:
Originally Posted by John Stephenson View Post
I'd just like to know if the sheathing in panel causing overheating to the conductor.
For practical intents and purposes, no.
With sophisticated equipment, I'm sure one could measure a slight increase after a while with a load on it, however, it would not be a problem.
I'm not recalling anything which prohibits sloppy work like that, other than ones own pride in their work (which, obviously, was non-existent there).
That is, other than the vague:
- NEC
- - 110.12 Mechanical Execution of Work.
- - - Electrical equipment shall be installed in a neat and workmanlike manner.
Old 05-16-2007, 09:25 PM
Jerry Peck's Avatar
Quote:
Originally Posted by Jeff Eastman View Post
I've wondered why the sheathing wasn't allowed more than 1 1/2 " (?) into panel.
I keep seeing HIs saying 1-1/2" or thereabouts, any idea where you got it from?
"Workmanship" would put it such that the outer sheather was trimmed off 'just inside the strain relief clamp'.
Quote:
I don't see where it would cause overheating or any other issue.
I don't see were running an NM cable, sheath and all, up almost to the breaker, then slit the sheath far enough to allow the grounding conductor to reach the grounding terminals, the neutral conductor to reach the neutral terminals, and the hot conductor to reach the breaker. Sure, it would "look" *ugly as sin*, but I don't know what problems it would cause, other than contributing to physical excess fill - but if the sheath puts you into an 'overfill' condition, I suspect it was already overfilled with conductors.
Anyone have an authoritative source on that 1-1/2"? I mean a *real* authoritative source.
Similar Threads
Electrical cable water heater dan orourke Plumbing System: Home Inspection and Commercial Inspection 3 05-01-2007 12:02 AM
Freestanding patio cover Eric Laney Exterior Systems: Home Inspection and Commercial Inspection 5 04-30-2007 10:48 PM
Insulation type Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 6 04-07-2007 09:47 AM
Table of Contents on the Cover Page? Mike Paris H E L P ! 2 04-02-2007 12:47 AM
vB.Sponsors
Ad Management by RedTyger
