Old 05-17-2007, 02:14 PM
John Stephenson John Stephenson is offline
Double taped breakers
Old 05-17-2007, 02:16 PM
wayne soper's Avatar
Re: Double taped breakers
The heat that trips the breaker can be absorbed by the other wire long enough to start a fire down the line.And you mean Tapped right?
Old 05-17-2007, 02:20 PM
Scott Patterson's Avatar
Quote:
Originally Posted by John Stephenson View Post
I know it is wrong to double tape the breakers. Saw two hots today going to one 20amp breaker. Exactly what problem does it cause when you double tape a breaker?
1. The breaker is not designed for more than one wire, unless it is one by Square D and I think that Cutler Hammer makes one as well. They are not all that common, but you will see them from time to time.
2. The connections can never be made tight with two wires. One will always be looser.
3. Loose wire will arc and or overheat.
4. A fire will start and the house will burn down.
5. You will be named in the lawsuit and you will also be named in a subrogation lawsuit by the insurance company.
Off the top of my head I can't think of much more at this time!
Scott Patterson
Old 05-21-2007, 06:51 PM
John Steinke's Avatar
John Steinke John Steinke is offline
Let's not be hasty ....
There are a number of breakers out there that are listed for having two wires attached to the one lug.
If such a breaker is used, it is perfectly OK to have two wires going to that breaker.
If it is not such a breaker, you do have a code violation. The risk is from a fear that one, or more, of the wires will be loose, leading to heat issues. There is also the fear that the multiple wires will take up more space than the clamp is intended to open ... again, leading to a loose connection.
The same principle applies to any wiring connection, even wire nuts. If you connect the wrong wires, or too many wires, the connection may not be reliable.
Please note that I say "may." The fact that something is not listed for more than one wire does not mean a good connection is not possible; it may simply mean that the manufacturer never asked UL to evaluate it for more than one wire. The difference is moot; you still have a code violation.
Old 05-25-2007, 09:50 AM
Joe Tribuzio's Avatar
Joe Tribuzio Joe Tribuzio is offline
There are some breakers that are doubled up in the space of one breaker, that is,for example two 15 amp w connectors but thinner in the footprint of one 15 amp breaker. I'm sure lots of you have seen them. Why not use one of them, presuming they are available for the brand of panel box.
Unless someone has had or has heard of bad experiences?
Just a thought
Joe
  #6 (permalink)
Old 06-07-2007, 07:06 PM
JD Johnson JD Johnson is offline
OK - just a quick question to confirm my understanding about which breakers can accept two wires...
IF the Square D breaker shows ONLY a single wire icon or image on the side of it, then it is designed to accept only a single wire correct?
Thanks in advance for your words of wisdom - I tried searching for a picture that shows the difference, but I may have imagined such a photograph.
Best regards and inspect safely - jdj
  #7 (permalink)
Old 06-08-2007, 12:08 PM
Michael Greenwalt's Avatar
Michael Greenwalt Michael Greenwalt is offline
John, could you please provide us with a list of the "number of available breakers" beyond the two most of are already aware of.
Issue: The coefficient of friction of two wires, drawing different amperage produces the effect of expanding at two different rates. Thus back to the original issue with aluminum branch wiring and the ability to loosen the connection, provide arcing, provide heat, provide fire,...etc. Engineer fix: 1 wire = 1 breaker. AL branch wiring = AL rated equipment.
Similar Threads
Double at Main Nick Ostrowski Plumbing System: Home Inspection and Commercial Inspection 8 05-19-2007 12:05 PM
Cu AL breakers dan orourke Electrical Systems: Home Inspection and Commercial Inspection 5 05-02-2007 09:20 PM
Double wired breaker Michael Vasquez Electrical Systems: Home Inspection and Commercial Inspection 23 04-27-2007 07:07 AM
vB.Sponsors
Ad Management by RedTyger
