Old 02-10-2009, 01:24 PM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is online now
No Access to disconnect...
Condo inspection today. There are closed panels with tamper proof fasteners on the side of exterior. I can only guess that the SEC, main disconnect and meter are inside? Isn't there a code that requires accessibility to the main disconnect?
HomeGauge Reports
Old 02-10-2009, 01:27 PM
Fred Warner's Avatar
Fred Warner Fred Warner is offline
Re: No Access to disconnect...
Quote:
Those ells look like plumbing ells, not conduit. Is this really electric work?
Not knowing with the slightest degree of accuracy I could not presume to designate per adventure I might err.
Old 02-10-2009, 01:32 PM
Ya, there PVC. Went all the way around the complex and there is one box for every two units. Sub-panel (thats for JP) in the laundry room. Neutral and grounds seperated, more than 6 disconnects.
Jerry Peck's Avatar
I'm thinking that goes to irrigation sprinklers and rain sensor switch, or maybe communication stuff??
Still not right with those elbows like that. Probably all of it is white plumbing PVC.
Old 02-10-2009, 01:36 PM
There is a possibility you are right! The only other place for SEC etc. is in Green metal boxes out in the community yard. They are pad locked so no way of telling what is inside anything! Shouldn't there be access available somewhere?
  #6 (permalink)
Old 02-10-2009, 02:13 PM
Jerry Peck's Avatar
Yes, there is a code which requires the service equipment to be readily accessible, have required working space in front of it, etc.
Well, the service entrance conductors are not required to be accessible, but you would be able to see the ends of them (unless in a combination enclosure where metal bus bars fed the service equipment from the meter) at the service equipment, which is required to be accessible, etc. (see above).
If there is underground service, you are possibly thinking about the service laterals.
If those boxes are pedestals, depending on their size, they may well be for cable TV, in which case they ran from the pedestal where the main cabling runs around the development and is stubbed up into those pedestals, then it was run to the buildings and run around the buildings to catch each unit.
Being as those area condos, all the service equipment would be in one location, possibly on one end of the building, in a meter room, or ????
  #7 (permalink)
Old 02-10-2009, 02:22 PM
Cable TV makes sense! I looked everywhere for equipment room etc. Guess I'll just say I could not find it!
  #8 (permalink)
Old 02-12-2009, 10:47 AM
Michael Mills Michael Mills is offline
It's possible that the locked green metal boxes you referred to in the yard might be POCO splice boxes or transformer enclosures.
Mike
  #9 (permalink)
Old 02-12-2009, 10:55 AM
I went back and found the service, under the stairs near the middle of the building, covered with a piece of plywood.
I should have looked harder at the time of inspection, but I was afraid of getting shot poking around other units.
  #10 (permalink)
Old 02-12-2009, 11:38 AM
Michael Thomas's Avatar
I'm seriously considering getting a reflective safety vest like one's the meter readers wear for inspections in the city - hopefully it would make it less likely I'll be confused with someone there to "borrow" cooper plumbing or personal possessions.
  #11 (permalink)
Old 02-12-2009, 12:36 PM
Quote:
That seems like a really good idea.
  #12 (permalink)
Old 02-12-2009, 01:09 PM
Jerry Peck's Avatar
Quote:
I've thought about it too, but the one I one looking at getting said "Crime Scene Unit" on it. Basic C.S.I. T-shirt from Zazzle.com Then my better judgment kicked in and ...
(that was long before CSI ever came on TV, thus that was not the shirt I had in mind, I was looking at a vest, which I cannot find now)
After all, are we not inspecting "the scene of the crimes committed by the various contractors"?
  #13 (permalink)
Old 02-12-2009, 01:35 PM
.........After all, are we not inspecting "the scene of the crimes committed by the various contractors"?
Kinda wonder sometimes.........
FREA Home Inspector Insurance
Similar Threads
Gas meter access. Vern Heiler Plumbing System: Home Inspection and Commercial Inspection 14 11-20-2008 06:37 AM
Attic Access Jim Robinson General Chit Chat: Home Inspectors & Commercial Inspectors 6 03-08-2008 04:26 PM
Attic Access Hatches Erol Kartal Attic Areas: Home Inspection and Commercial Inspection 13 08-15-2007 08:46 AM
Attic Access Requirements dan orourke Attic Areas: Home Inspection and Commercial Inspection 2 07-14-2007 08:18 PM
Furance Access. Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 05-02-2007 03:57 PM
vB.Sponsors
Ad Management by RedTyger
