Old 05-26-2007, 04:43 AM
David Shipe David Shipe is offline
Sub Panel
What year did nec. mandate four wires for a sub panel, residential wiring
Old 05-26-2007, 05:01 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Sub Panel
Don't have answer for your question but I'd like to clarify. Perhaps it would be better to say four conductors. In our area most wiring is in metal conduit which serves as a conductor. So for subpanel, three wires in conduit would suffice.
Eric Barker
Barrington, IL
Old 05-26-2007, 05:15 AM
John Arnold John Arnold is online now
Re: Sub Panel
Hmmm ... I'm having trouble finding the term "subpanel" or "sub panel" in my 2002 NEC ...
Maybe Jerry P. knows something about this ...
Old 05-26-2007, 05:54 AM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Re: Sub Panel
We have a trouble maker here.
I say lets merge all the home inspection organizations into one.
Seepaluce
Old 05-26-2007, 06:01 AM
Re: Sub Panel
I resemble that remark.
  #6 (permalink)
Old 05-26-2007, 06:36 AM
Richard Rushing's Avatar
Re: Sub Panel
make the bad man go away....
Richard Rushing, HCRI
Duncanville, Tx.
  #7 (permalink)
Old 05-26-2007, 06:49 AM
Thom Walker's Avatar
Re: Sub Panel
Evil. Pure evil.
- Paul Fix
  #8 (permalink)
Old 05-26-2007, 06:54 AM
Re: Sub Panel
I've only seen one "sub panel", it was in a "submarine", so it *was* a "sub panel".
The question, I think, is when did the NEC require the neutral to be bonded 'only at' the "service equipment".
Without going back and checking through my old codes, I'm guessing that it was 'aways' that way, just not clearly stated as such. I' think I recall that the wording was clarified in the 1920s, with continued clarification in subsequent codes as needed, ending up with the current wording.
Regardless, though, of when the code clarified the wording, it is not safe and should be written up when found - however old the house is.
  #9 (permalink)
Old 05-26-2007, 07:13 AM
Re: Sub Panel
Okay, who are you and what have you done with Jerry? If you hurt him, we'll hunt you done like dogs.
- Paul Fix
Home inspection
Similar Threads
Clearances for Panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 3 05-02-2007 02:53 PM
Paint in Panel David Banks Electrical Systems: Home Inspection and Commercial Inspection 46 05-02-2007 06:13 AM
condo panel box william siegel Electrical Systems: Home Inspection and Commercial Inspection 10 04-26-2007 07:40 AM
Hot tub Panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 05:39 PM
From the old board, Wet Panel Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 0 04-01-2007 11:38 PM
vB.Sponsors
Ad Management by RedTyger
