Welcome to InspectionNews.
Registration is FREE!
11-03-2009, 10:41 PM
Under-Cabinet Lighting Splitter
Kitchen under-cabinet lighting is tied into a splitter that is plugged into the outlet. The microwave is plugged into the other plug at the duplex outlet in the cabinet above the microwave.
1) Is this splitter an "approved" device?
2) The under-cabinet lighting is ungrounded (two wires) and is not GFCI-protected in locations near the sink. Would you recommend repairs or removal?
(Yes, I noted the open splice in the one wire.)
Bruce Breedlove
www.avaloninspection.com
11-03-2009, 10:51 PM
Re: Under-Cabinet Lighting Splitter
Bruce,
Boy, that is pretty weird looking. I would certainly recommend corrections.
Reality is a crutch for people who can't handle drugs.
11-04-2009, 07:53 AM
Looks like a flexible multi-tap adapter that you can buy at the hardware store.
If the microwave instructions called for a dedicated circuit you would have a technical violation as it is now being shared with the lighting.
There is no requirement for the lighting to be GFI protected.
11-04-2009, 01:29 PM
Those stupid line-voltage puck lights are bad on many levels, but hey, they are easy for Harry Homeowner to install.
11-06-2009, 04:47 PM
Yes, would you call it an amateur installation and recommend an upgrade to the low voltage lights? I think I would.
11-06-2009, 06:18 PM
John,
I'm confused here ... why would you call replacing something which is not right with something which is an "upgrade"?
I call that a "correction" or "repair".
11-06-2009, 06:24 PM
Originally Posted by Jerry Peck
John,
Cuz that is what an upgrade is? Are we speakin the same language here?
11-06-2009, 06:52 PM
Huh?
An "upgrade" is not a "repair" or a "correction".
Like this:
- I'd like to buy that car but with a radio which has a CD player.
- No problem, that is just a simple UPGRADE, it only costs ... more.
Or this:
- I'd like you to repair my car radio, it is not working.
- No problem, and if that radio is not repairable we can replace it with the same thing.
- Well, if you are going to replace it, I would like one with a CD player.
- No problem, we can UPGRADE the radio to one with a CD player when we replace it, it only costs ... more.
You are in Canada, so I'm not sure what language you are speaking.
11-06-2009, 07:07 PM
Huh?
The light's not broken, how can it be repaired? To "correct" that installation, plug it into another outlet that is not designated for the MV.
To improve that temporary situation, "upgrade it".
Neither am I, eh?
11-06-2009, 07:09 PM
Jerry, did you read what he wrote?
11-06-2009, 07:14 PM
Jim,
I did, and what he should have said was to have it repaired.
That is a deficiency and reportable.
THEN he could have added something about an "upgrade", but by simply stating to "upgrade" it, there is no deficiency to report, and if there is no deficiency, why "upgrade" something which is okay?
The only way the client benefits is for home inspectors to report deficiencies as such, not to call them "maintenance" or "upgrades".
I have seen reports where EVERYTHING was an "upgrade", even the leaky roof with shot shingles.
11-06-2009, 09:33 PM
I concede, that installation needs to be grounded and GFCI protected in the US. MY bad.
11-07-2009, 06:09 AM
Since when is something that needs maintenance a deficiency?
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
11-07-2009, 10:57 AM
I don't think JP said that it was, just that we should not call for maintenance (or an upgrade, either  ) when there is a deficiency.
This plug-in lighting does not meet code standards of today, so Jerry says it is a deficiency, repair it.
I am not sure when the lighting was installed, and if it was ever acceptable in that jurisdiction, so I am backing away slowly.
We don't tell people they need to repair the wiring if the installation was code compliant when installed. However, if they were to unplug these lights, they're apparantly not allowed to plug them back in!  I'm outta here.
11-07-2009, 03:34 PM
John Kogel, your post dated: 09/07/09
"This plug-in light does not meet code standards of today".
What light are you talking about?
I look at Bruce Breedlove photo, and saw no luminaire.
And what code are you talking about?
How you don't mine my questions, but I am on this site to learn, so a
little help here, please.
11-07-2009, 04:29 PM
I did not take a photo of the under-cabinet light fixtures. (I saw no need.) They were similar to the one shown in the photo below.
Bruce Breedlove
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Flex connector below cabinet? |
Trent Tarter |
21 |
09-01-2009 03:35 PM |
| Flexible Gas Line and Shutoff in Cabinet |
Matthew Barnicle |
25 |
01-24-2009 09:04 AM |
| cabinet over fridge |
John Arnold |
Building Interior: Home Inspection and Commercial Inspection |
3 |
04-16-2008 05:42 PM |
| surge in main cabinet |
Jerome W. Young |
16 |
04-01-2008 08:42 AM |
| Outlet in FP cabinet |
John Stephenson |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
1 |
06-06-2007 06:05 PM |
