06-18-2007, 01:57 PM
Electrical tape
06-18-2007, 02:46 PM
Re: Electrical tape
Jeff, how did you see the taped cable? Is it plainly exposed or did you need to remove a coverplate to see it?
06-18-2007, 04:57 PM
Re: Electrical tape
If the builder put it in writing, then he is accepting responsibility for it. You have made your recommendation.
The apostrophe troll.
06-19-2007, 07:02 AM
Re: Electrical tape
Tell the builder to 'show me the code section which states that' ... or replace it.
06-19-2007, 07:06 AM
Re: Electrical tape
Originally Posted by Jeff Eastman
My comment in my report:
"Electrical cable damaged and has improper repairs (taped) at upstairs left rear bedroom door entry topplate".
Builders' Comment:
"Electrical tape by code is considered insulation rated!"
Is this true??
Jeff,
While the builder should be able to back-up his statement... he won't. It will then be where he will challenge you with code to back-up your statement and finally become a pissing-contest that will eat up alot of your time and effort.
You saw, you identified, you reported.... time to move on.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
06-19-2007, 07:12 AM
Re: Electrical tape
Originally Posted by Richard Rushing
Jeff,
The BUILDER said "Electrical tape by code is considered insulation rated!"
Which is why I said "Tell the builder to 'show me the code section which states that' ... or replace it."
Jeff just stated it was damaged and needed repairs, he did not cite code - THE BUILDER DID, so let the builder back it up.
06-19-2007, 07:24 AM
Re: Electrical tape
We are not saying anything different... just different ways.
The builder WON'T provide the code (he can't). He will say, "It been fine that way since Moby-Dick was a minnow and now this guy (Jeff) want's to say we can't do it this way?" "Why?"
Then the buyer turns to Jeff and says, "You can provide back up for that right?"
That's where it ALWAYS (by the builder or contractor) becomes a pissing contest because it eats up your time and energy that you should be spendig on doning another inspection, or writing a report or tickling ma-ma.
My point is that the buyer doesen't know anything. He is going to ask everyone to provide back-up for what they stated.... even though, the builder was the one who mentioned "code".
Rich
Duncanville, Tx.
06-19-2007, 07:41 AM
Re: Electrical tape
That's when Jeff gives his client 300.4, NEC (bold is mine).
- 300.4 Protection Against Physical Damage.
- - Where subject to physical damage, conductors shall be adequately protected.
(then it goes on being more specific about various things)
The fact of the matter is, if tape was needed, *they were NOT "adequately protected"*.
Then follow that with 'And the code does not tell you that you are allowed to repair damaged conductors.'
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Electrical help needed |
william siegel |
7 |
06-22-2007 06:30 PM |
| Air ducts/electrical cable |
RobertSmith |
1 |
06-06-2007 08:52 PM |
| Electrical cable routing |
Jeff Eastman |
2 |
06-05-2007 09:39 PM |
| electrical support |
John Arnold |
3 |
05-25-2007 11:13 PM |
| Foil tape on vent pipe |
Jeff Eastman |
5 |
05-18-2007 05:12 PM |
