06-20-2007, 05:30 PM
FPE main disconnect
I did a house today that had a FPE main disconnect on the outside wall of house, 200 amp. On the other side of the wall was a newer Square D panel also with a 200 amp disconnect. I recommended replacement or just getting rid of the FPE main since there was one inside. The inside Square D was wired as a "sub" neutrals and grounds seperated and not bonded together. Is it ok to get rid of that FPE or should it be replaced with another 200 amp main outside...
06-20-2007, 05:35 PM
Re: FPE main disconnect
I am not aware of any problems with the 200 FPE main breakers. If it is an isuue then it should be replaced with another 200 amp main unless the insde panel is made into the service panel.
06-20-2007, 06:52 PM
As a generalist home inspector, I would question the FPE main and defer to an electrician.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Panel, utility meters, a/c disconnect boxes. |
Jeff Eastman |
0 |
06-19-2007 11:09 AM |
| Double at Main |
Nick Ostrowski |
8 |
05-19-2007 12:05 PM |
| AHU disconnect |
Jerry Peck |
5 |
05-16-2007 08:34 AM |
| A/C disconnect location |
Jeff Eastman |
6 |
05-08-2007 06:13 PM |
| a/c disconnect |
Martin lehman |
6 |
04-04-2007 12:48 AM |
Ad Management by
RedTyger
