Old 06-26-2007, 10:45 PM
John Stephenson John Stephenson is offline
Auto opener switch on GFCI
Home inspection
Old 06-26-2007, 11:27 PM
Rick Hurst's Avatar
Re: Auto opener switch on GFCI
I don't think it is nothing but a poor location. Why is having anything connected to a GFCI receptacle wrong?
I know you wouldn't want maybe a refrigerator / freezer on a GFCI in case it tripped, you might have a spoilage problem.
Dumb idea, yeah.
Old 06-27-2007, 06:21 AM
IF the receptacle outlet is above 6'8" above the floor, it is typically considered not 'readily accessible' and thus does not need GFCI protection.
However, as stated in other posts regarding motors and so-called 'nuisance tripping', the allowable ground fault for motors is about 1/100th of that which trips a GFCI. Thus, if the motor is tripping a GFCI, the motor/appliance needs to be replaced. Don't remove the GFCI protection, replace the problem - the motor.
Old 06-27-2007, 09:39 AM
Richard Stanley Richard Stanley is offline
When I encounter that set up, I note it in the report and caution the client as to the possibility of an inconvenince - remote won't work if circuit is tripped.
Old 06-27-2007, 07:54 PM
Quote:
Originally Posted by John Stephenson View Post
I was thinking the switch/auto door opener needs to be on its own dedicated branch circuit.
Nope.
Home inspection
Similar Threads
GFCI question dan orourke Electrical Systems: Home Inspection and Commercial Inspection 16 07-01-2007 07:54 AM
Garage Auto Opener Button Location Jeff Eastman Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 06-22-2007 06:16 PM
Switch for shower fixture Michael Greenwalt Electrical Systems: Home Inspection and Commercial Inspection 4 06-22-2007 12:59 PM
Light switch location Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 8 04-19-2007 12:57 PM
Light switch position. Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 4 04-18-2007 07:03 PM
vB.Sponsors
Ad Management by RedTyger
