Share |
Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Home Inspector Essentials
Old 03-19-2010, 06:15 AM
Tom Rees Tom Rees is offline
Double Taps
How can you tell which Square D breakers are designed for two wires at screw down?
Home inspection - The Cost Of Business.
Old 03-19-2010, 06:19 AM
Rick Cantrell Rick Cantrell is offline
Re: Double Taps
If you got really, really good eyes, you might be able to read it on the breaker, or you can look at the terminal clamp.
Old 03-19-2010, 07:21 AM
Jim Port Jim Port is offline
Re: Double Taps
Sq D 15-30 amp breakers are listed for one or two conductors. Larger sizes are for one conductor only.
Old 03-21-2010, 06:24 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
Re: Double Taps
Here is whats printed on the side of the SQ-D's.
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
Old 03-21-2010, 06:27 PM
Re: Double Taps
That pic was too small. Here's another.
  #6 (permalink)
Old 03-22-2010, 03:52 AM
Chap Fichera's Avatar
Chap Fichera Chap Fichera is offline
Re: Double Taps
But that's only for the same gauge wire on each breaker?
  #7 (permalink)
Old 03-23-2010, 01:39 AM
James Risley James Risley is offline
Re: Double Taps
Quote:
Different size wires within the stated range on the breaker can be used. Note that one wire can be used so that the total absence of the second wire will not affect the proper clamping of the first wire. The radius of the positioning formation of the clamp is such that it will provide the proper contact area for those stated wire sizes. That is to say the use of a smaller guage wire under the clamp (be it one or two wires) cannot be used because proper clamping force between the clamp and the wire cannot be accomplished. A wire size larger than the stated size (be it one or two wires) cannot be used because the surface area contact between the clamping surfaces and the wire(s) would not be sufficient due to the radius of the positioning formation being two small for the larger wire(s). Depending on the design of the clamp some breakers and other devices may not be as restrictive of wire size ranges but allowable wire sizes should be indicated on the device.
United Infrared
Share |
Similar Threads
Well Pump Disconnect Double Taps Bruce Breedlove Electrical Systems: Home Inspection and Commercial Inspection 1 11-12-2009 04:54 AM
Double Taps Re-visited Victor DaGraca Electrical Systems: Home Inspection and Commercial Inspection 26 08-23-2009 06:38 AM
Double Taps Roni Litmanovic Electrical Systems: Home Inspection and Commercial Inspection 13 01-10-2009 12:07 PM
Double taps Chip O'Brian Electrical Systems: Home Inspection and Commercial Inspection 27 08-13-2008 07:29 PM
Double Taps wayne soper Electrical Systems: Home Inspection and Commercial Inspection 7 07-24-2007 12:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
