Old 07-16-2007, 10:15 AM
David Macy David Macy is offline
Height requirement for exterior box
This GFCI controlled outlet was at ground level.
What if any requirements are for the height of the box?
Old 07-16-2007, 10:25 AM
John Arnold John Arnold is offline
Re: Height requirement for exterior box
David - I don't know the answer to your question, but it immediately occurred to me to see where you are from, thinking about snow, for one thing, but you haven't filled out your profile.
Old 07-16-2007, 10:31 AM
Quote:
I am from snow country in Northeast Ohio.
I will have to update my profile.
Old 07-16-2007, 10:42 AM
2006 IRC E3801.7 Outdoor outlets. At least one receptacle outlet accessible at grade level and not more than 6 feet, 6 inches above grade, shall be installed outdoors at the front and back of each dwelling unit having direct access to grade.
Old 07-16-2007, 10:54 AM
So from the IRC it is acceptable to install at grade level. So what if it snows 6-12 inches?
  #6 (permalink)
Old 07-16-2007, 10:57 AM
Quote:
I don't know. Seems like a concern to me. I did notice in my CodeCheck Electrical it says "In most cases. the NEC does not have requirements for switch or receptacle height", then goes on to talk about the Americans with Disabilities Act.
  #7 (permalink)
Old 07-16-2007, 11:45 AM
Bob White's Avatar
Bob White Bob White is online now
Not sure what code says about it, but that receptacle looks like lawn mower candy to me....
Bob White
www.abide-able.com
  #8 (permalink)
Old 07-16-2007, 11:51 AM
Quote:
Actually I would do a nice number on the box with my weadeater!
By the way How do you like my profile. This is the time of year I usually go to Canada and unfortunetly will not be going this year.
I hear the loons, labatts and fish calling me!!
  #9 (permalink)
Old 07-16-2007, 03:56 PM
If it is buried at all, it must be a direct burial rated box ... which means gasketed cover and no openings (like receptacles) which could allow water in.
If it is 'just above grade' but in a depression area and you see a high water mark around it, I wrote them up as needing to be direct burial/underwater rated.
If it is 'just above grade' and no evidence of water ... there is no 'minimum height' requirement.
Similar Threads
electric eye height wayne soper Exterior Systems: Home Inspection and Commercial Inspection 10 06-10-2008 09:39 AM
Interior stairway riser height dan orourke Building Interior: Home Inspection and Commercial Inspection 6 06-19-2007 06:47 AM
Exterior steps dan orourke Building Envelope: Home Inspection and Commercial Inspection 4 05-30-2007 04:30 PM
Plumbing vent height John Stephenson Plumbing System: Home Inspection and Commercial Inspection 17 05-23-2007 12:44 PM
Exterior JB Warren Alderman Electrical Systems: Home Inspection and Commercial Inspection 3 04-12-2007 05:56 PM
vB.Sponsors
Ad Management by RedTyger
