Old 07-18-2007, 09:18 AM
dan orourke dan orourke is offline
Electrical cable inside of chimney chase
Old 07-18-2007, 04:59 PM
Scott Patterson's Avatar
Re: Electrical cable inside of chimney chase
How would you have proper fire blocking if the chase has a cable running through it? I'm going to say that it is a No, No.
After I think about it for a moment, I guess you could have an outlet or line for the fireplace to power a blower. But it would not be running down the chase.
Scott Patterson
Old 07-18-2007, 08:11 PM
Just keep the NM cable away from the chimney vent.
If the cable runs through a firestop, seal around it just like you do when a cable runs through a top plate (fireblock).
Old 07-18-2007, 09:29 PM
Bob Harper's Avatar
The rest of the chase is ordinary construction. As long as the cable is stapled and fireblocked, I see no problems. Done all the time.
bob
Similar Threads
exterior electrical cable. Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 6 07-06-2007 06:14 PM
Electrical cable location Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 0 06-22-2007 04:57 PM
Electrical cable in Chimney Chase John Stephenson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 13 06-22-2007 08:24 AM
Air ducts/electrical cable RobertSmith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 06-06-2007 08:52 PM
Electrical cable routing Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 06-05-2007 09:39 PM
vB.Sponsors
Ad Management by RedTyger
