Old 07-23-2007, 06:23 PM
M Kelekci M Kelekci is offline
Receptacle-cook top clearence requirement.
Is there any minimum clearance requirement between receptacles and cooktops?
Thanks as always.
Matt Kelekci
Houston TX
Home inspection
Old 07-23-2007, 07:40 PM
Re: Receptacle-cook top clearence requirement.
'No', and 'yes'.
'No' as far as the national electrical code goes.
'Yes' as far as the installation instructions for that appliance goes (and the Fuel Gas Code requires appliances to be installed in accordance with their installation instructions) due to the requirement for surfaces on that wall to be able to withstand a minimum 200 degrees (or is it usually 250 degrees) and some larger gas cooktops even require a higher heat resistant material back there.
I doubt that plastic will withstand the temperature specified.
Old 07-28-2007, 09:57 AM
John Steinke's Avatar
John Steinke John Steinke is offline
Not just 'no,' but 'heck no.'
It was once common for stoves to have receptacles built into them ... in just about the location shown. Mighty convenient for plugging in the mixer ... especially as that was often the only receptacle in the kitchen.
Such a feature seems to have gone away when the code began to want GFCI's in the kitchen.
Old 07-28-2007, 10:26 PM
Trent Tarter Trent Tarter is offline
Re: Receptacle-cook top clearance requirement.
Matt, I would most definitely call that out. I would not worry about any clearance requirement common sense says that it could easily be damaged by heat or that boiling water could easily splash onto the outlet.
Home inspection
Similar Threads
Height requirement for exterior box David Macy Electrical Systems: Home Inspection and Commercial Inspection 8 07-16-2007 03:56 PM
Receptacle Outlet Location dan orourke Electrical Systems: Home Inspection and Commercial Inspection 3 07-15-2007 05:38 AM
Gas line for cook top routed through down draft vent allen elliott Plumbing System: Home Inspection and Commercial Inspection 2 06-01-2007 09:02 PM
Help needed with ID of receptacle Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 4 04-24-2007 06:50 AM
Receptacle for refrigerator Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 6 04-14-2007 12:47 PM
vB.Sponsors
Ad Management by RedTyger
